- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Using RBS50 Sattelite intermittently causes buffering and speed to crawl
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBR50 router with two RBS50 satellites. For 3-4 months, everything seemed to work great. In the last week (with no changes having been made on my part), one of my satellites has had serious issues. Any devices connected to that sattelite (either wifi or plugged in ethernet) will intermittently get very slow speeeds. Constant video buffering is a huge issue as this satellite powers our living room TV. When I get video buffering, I pull out my phone and it also will go very slow and hang when trying to open up webpages.
I tried turning off the satellite entirely and letting everything go through Wifi either the router or the other satellite in my house. This completely fixes the issue and no buffering issues.
How can I troubleshoot and fix this issue? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Using RBS50 Sattelite intermittently causes buffering and speed to crawl
Turn OFF all the other RBS and leave the one RBS online.
Swap RBS postions with another to see if the problem follows.
Factory reset the one RBS and re-sync it to the RBR while the other RBS or turned OFF. Test.
Is Daisy Chain enabled on the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I took satellite 1 (the one giving me issues) and replaced it with satellite 2. I left satellite 1 turned off.
I still had the same issue with satellite 2.
I am using the latest firmware ( v2.5.1.16)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What about that link?
Also...I manually updated the firmware to 2.5.1.16 yesterday hoping that would fix my issues. It did not...same issue as the previous firmware I was on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@liftingbrosef wrote:What about that link?
They're asking you to post your experience with your firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
So a known working satellite in place of the one that is giving problems is now experiencing same problems?
Does the 1st problem RBS work in place of the original RBS position?
Seems like some interferences going on at the problem RBS location thats causing the RBS to not work right.
Has a reset on the RBR and RBS been performed as if yet?
No need to post anywhere else, just post here.
@liftingbrosef wrote:I took satellite 1 (the one giving me issues) and replaced it with satellite 2. I left satellite 1 turned off.
