- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
V1.3.0.12 - Outstanding Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model: Netgear Orbi RBK50 (Orbi Base + Satallite)
Firmware: V1.3.0.12
OS: Not relevelnt, but Wndows 10 Pro x64 anyway
Browsers: Any, Primary Browser is Chrome though.
I have seen several people mention issues with the Netgear Orbi router on the netgear forums lately. I also have seen several people mention some fixes/workarounds. I just thought it would make sense to try to document the ones i'm able to confirm and am experiancing in a single post.
- Issue: Wifi randomly dropping Nest Wifi cameras. Specifically NestCam (5ghz) and Dropcam HD (2.4ghz). Both cameras drop at similar times and it happens multiple times per day.
- Workaround: Go to the "Advanced" tab -> Advanced Setup -> Wireless Settings and uncheck "Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices"
- With this setting left enabled, the cameras will work just fine but several times per day they will drop for 10-15 minutes, typically 5-6 times per day.
- Issue: Attached Devices has a bunch of unknown devices even though this was listed as an issue that was resolved in the latest firmware release.
- Example:
- Note: Above screenshot was taken after enabling adavnced device details view from debug section, but same thing is noticed when you view the default setting
- Example:
- Wifi connects but seems to not provide an internet connection at random. We noticed this mainly at night when we are winding down before bed and typically using iOS devices (ipad pro, iPhone 6S/7 Plus).
- I'm still troubleshooting this one but so far, i think its got something to do with the satallite. My next step is probably going to be trying to just unplug the satallite for a day or two and see if we still continue to see the same issue.
- We typically always notice this on facebook, the feed simply does not update and as soon as we toggle wifi off and refresh, like magic everything updates. Flip wifi back on and it may work, but eventually it stop working again and you either have to wait a bit and then it starts working or toggle wifi off for a bit and then reconnect again. Like i said, more troubleshooting needed here as i'm not entirely sure what causes this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: V1.3.0.12 - Outstanding Issues
yup i concur with the unknown connection issue
however i dont have any devices that have issues but the nest issue is a known one
have no issues with connectivity but i also only run the orbi in ap mode at the current time and let me router ( asus rt-ac88u ) do all the heavy lifting
pete
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure what to say, honestly - our family has four iPhone roaming around the house without issue.
What model iPhone is having trouble?
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My wife's iPhone is a 7 Plus and mine is a 6S Plus and we both see the issue. Typically its when we are upstairs (the satallite is upstairs and the base unit is downstaris) that we notice it, thought sometimes we notice it in my living room but thats a pretty equal distance between both the base and the satallite so what i need to pay more attention to is which device its connected to when this issue occurs to see if i can find a pattern.
I may just unplug the satallite tonight and see how the rest of this week goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't seen any issues at all with the 3 iPhone 6 Pluses we have. There is also an iPhone 7 here, but it's my mother-in-laws and honestly if it were having any issues with wifi I sincerely doubt she'd notice. I'll do a bit of testing with her device to see if I observe any problems.
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
So keep in mind that what i'm seeing is specifically around facebook. What you'll notice is that facebook "seems" like its working just fine, since they now have an offline mode where it simply shows you what it saw last time you had a valid connection, you may not even realize you're not online or updated. You can check this by making sure that facebook is set to view your "most recent" feed instead of the now default view which puts posts facebook thinks are most important first (which may even be a day or two old).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Those with iPhone (and Facebook on iPhone) issues - is Orbi configured in router or AP mode?
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I asked because I am in AP mode and not seeing the issues you are describing, which suggests (at least) that the issue is likely more on the routing side than the wireless side.
If possible, perhaps one/both of you would like to consider putting your old router into place, disabling wifi services on the original router and running Orbi in AP mode to see if the problem goes away?
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Fivef555 wrote:
I no longer have my own router to give it a try. To be honest although the phone worked fine on the X8, I am not convinced that this isn't an IOS 10 issue as well. I work for a large electronics retailer and a log of people are having issues with connectivity after the update and it seems that it's random as far the phones it effects.
Useful data point! None of our iPhones have been upgraded to 10 (deliberately).
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
See the same issue with the kids 2 iphone 6 and sometimes with mine. Is the resolved in V1.3.0.26? I am at this version now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
general question regarding this passphrase thing
are ppl using an ssid that they have used before on other routers or are you using a new and unused ssid for the orbi system ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@peteytesting wrote:general question regarding this passphrase thing
I came from an Asus 5300, and I kept that primary SSID/password when I switched to Orbi. I have a couple of iPhones (SE and 6S) and an older Macbook Air, plus a variety of HA tools (Honeywell RedLink, SmartThings hub, Hue hub, Harmony hub, Google Home x5) - all have worked very smoothly on Orbi and the "old" SSID.
The only consistent glitch I have with the Orbi is whenever I need to reboot it (firmware update, etc)... It always takes a few reboot cycles to finally "catch" and fully connect to the interwebs. I've had this issue with both v12 and v26 of the firmware. But if that's the worst thing I have to live with for this router, I'll very happily do it!! 🙂
Cheers, Chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having same issue in AP mode random WiFi drops on variety of mobile devices including iPhone, iPads and Sony Xperia tablets. Switching channels reboots factory resets all performed many times. Un checking implicit beam forming has helped a little now reboots 2or 3 times a week rather than nightly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello JMU1998
Are you on the latest firmware? Have you noticed the wifi drops when your connected to the main router or the satellite?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I am on the latest fw and frequent WiFi drops on various wireless devices randomly several times a day on both main unit and satellite since going with latest fw.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello JMU1998
We just released 1.4.0.16 this release has alot of fixes in it you may want to try and upgrade and see if this improves the performance.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DarrenM,
After your message when I checked the router admin page I noticed one router and one satellite(2nd Floor) updated to latest firmware. So I went ahead and updated the remaining Satellite(1st Floor) to new firmware.
Now the 1st floor satellite won't stay connected and drops from admin page after few hours. Called tech support twice and exhausted all the support steps.
Since I bought it only a month back and during holiday I have returns with costco till Jan end. So I am going to return and see if new one has better luck.
Thanks,
Bijugm
