Reply
V2.5.1.16 connectivity issues
Guru
Re: V2.5.1.16 connectivity issues
What happens if you connect the RBS wirelessly to the RBR?
Also do you experience drop outs with the RBS turned OFF and just the RBR left up and running?
@daddydoitall wrote:
I have not factory reset and setup yet.
The RBR and RBSes are 30 to 40 feet apart but all connected via ethernet.
The modem is a Motorola SB6141.
The Orbi is running as a Router.
The ethernet switch is a Monoprice 8-Port 10/100/1000 Mbps Unmanaged Gigabit Ethernet Switch #15763
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 26 of 32
daddydoitall
Rolling back the firmware from 2.5.1.16 to 2.5.1.8 on the router and two satellites has stopped the wireless internet drops. I wonder what it was with the new frimware caused the problem. Thanks for everyone's help.
Message 27 of 32
Mstrbig
Master
Good question as my RBK53 system is rock solid on 2.5.1.16, auto updated on install from 2.5.1.8 when purchased.
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 28 of 32
Guru
I would have factory reset and setup from scratch. v16 has been solid and stable for me.
Message 29 of 32
daddydoitall
When I have time I will do that. Is a there anything special to do to make sure my 40 devices reconnect properly after resetting from scratch?
Message 30 of 32
Guru
30 feet or more  is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Message 31 of 32
Mstrbig
Master
I would Backup your settings. I would name your SSID the same as before.
After you are up and running, devices connected and fully tested, you could restore your settings to save time renaming, etc.. But if something in your settings was causing the issue it could bring it right back.
Message 32 of 32
Top Contributors
Discussion stats
  • 31 replies
  • 1967 views
  • 1 kudo
  • 6 in conversation
Announcements
