- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
VPN and Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
VPN and Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN and Orbi
I would ask the Mfr of that VPN to see if Orbi is compatible.
NG already uses OpenVPN I believe on there systems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN and Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN and Orbi
if you're installing it to your computer and just want it on there, it doesn't really matter what router you're running. it'll vpn fine.
If you're wanting it for all devices, then you need a compatible vpn provider.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN and Orbi
@Mercuryaces wrote:
........would like to subscribe to tunnel bear as my VPN service. Are these two compatible? .......
I'm using tunnel bear in my iPhone with no issues. I have Orbi at home. Orbi is transparent to such services. You don't need to do anything in Orbi for tunnel bear to work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN and Orbi
If you're talking about inbound remote VPN to access devices inside your network remotely then yes. Just go to Advanced > Advanced Setup > VPN Service and setup OpenVPN then download the profile to your devices. If you mean outbound VPN so only your router creates a site-to-site VPN then no, at least I haven't been able to find a way. I use express vpn which is working very fine any where in the world specially in china, even known as one of the best china vpn.
