korayb's avatar
korayb
VPN works, but public IP doesnt seem tunneled through (RBK50)
With the latest firmware version (V2.0.0.74) I have set up VPN -with NETGEAR DDNS.
Downloaded the opvn files to iPhone and when I enable VPN (openVPN app) it looks like its all fine.
My RemoteManagement setting is disabled.  But while VPN is active, I can login to orbis management interface with 192.168.x.1 -> This shows that VPN really works
But on my iphone when i go to http://www.whatsmyip.org/, it doesnt give me the public IP of my home, it shows the same IP when VPN is off -> This shows VPN doesnt really work.
Could you help me clarify, whats going on?
Kind regards,
  • VPNs do not always route all traffic through the remote server by default. This is set in the VPN configuration file.
    When you setup the VPN on Orbi make sure you check the box that says, "Clients will use this VPN connection to access"...  "All sites on the Internet and Home Network."
    • korayb's avatar
      korayb
      Thanks, I did exactly as you said.
      It told me to redownload the ovpn file, I did.
      I deleted the old ovpn from the phone, imported the new one. (I use openVPN application).
      Now, when VPN is turned on, i cannot access anything, including the router admin page.
      So my problem became:  VPN doesnt work at all, although I followed the instructions and didnt do anything fancy.
      Should I create a new topic as "VPN Doesnt work?"
      Thanks,
      • st_shaw's avatar
        st_shaw
        Master
        I don't think you need a new topic.
        It makes sense you needed to download a new ovpn file.  That's where the settings are saved, so anytime you change settings, the new file must be downloaded and transferred to your phone.
        Can you give some more information on how things are connected when nothing works? Apologies if any of the questions seem dumb, but I don't know anything about your setup or knowledge level. Some things to consider:
        1. Are you sure your router is accessible from the Internet?
        2. Can you get something simpler to work first, like Remote Access, to establish the router can be reached remotely?  See page 107 of the user manual here: http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
        3. If you change the settings back to Auto, can you access the VPN as before?
        4. Are you connecting from either 1) outside your home, or 2) from inside but with the phone WiFi disabled so the cellular radio is used?
        5. Have you tried the VPN from a Mac or Windows client?
        This video has a decent walkthrough of the setup.
        https://www.youtube.com/watch?v=7CRKV2DfugI
