Reply
Very low WIFI speed
Claxton
Follower
Very low WIFI speed
Just upgraded my broiadband supplier and now have 145 download. I have checked this on the wired computer and this is true. I have checked it on the ORBI app and again this is true. But when I use a broadband speed checker on my phone in various rooms in the house, im getting download speed via wifi if 40-60, even if I am right next to the main hub! What can I do to change this?
Model: RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 2
st_shaw
Master
Re: Very low WIFI speed
Could be that's as fast as your phone can go.
If you want to check your WiFi throughput, you should do so with a desktop or laptop with a WiFi adapter with good specs.  For Orbi you need 802.11 ac, support for 80 MHz channel width, and a link rate of at least 867 Mbps on 5 GHz.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 410 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
