Reply
WAN access to Orbi
Boatguy54
Guide
WAN access to Orbi
1)  Is there a way to change the user name?  Under Advanced settings I can change the password, but not the user name (2.1.1.16)
2)  When I access via the web interface, is this going through my LAN or via NetGear and the WAN?  If WAN, I would like to disable acces from the WAN.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 3
aaz
Virtuoso
Virtuoso
Re: WAN access to Orbi
Unlike some other mesh systems out there, Orbi is not controlled from the cloud - so LAN only. Unless you enable control via internet, and even that you can restrict to a specific IP.
Message 2 of 3
Boatguy54
Guide
Great!  How do I change the user name?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 616 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
