Orbi WiFi 7 RBE973
Reply
WAN link status shows as down in AP mode
rampi
Guide
When in AP mode, the WAN link status shows as down, is that expected ?
I've connected a Cat5e cable from the Internet port on the RBR50 to the LAN port on the other ISP router.
It is all working fine but seeing slower speeds -  will check more and will post separately on that.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: WAN link status shows as down in AP mode
The Internet/WAN port does become a LAN port logically in AP mode - perfectly right.
Message 2 of 4
All Replies
schumaku
Guru
Message 2 of 4
rampi
Guide
Thanks for the clarification.
But it will be good if the status gets displayed correctly as it will be useful to know what speed has been negotiated.
Anyway, thanks for the clarification.
Message 3 of 4
Guru
The WAN status isn't used while AP mode thus will not be reported as online or connectred while in AP mode. Thus the display will not be used as a reporting status while in AP mode. Just look at the LAN status for your information needs.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1622 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
