- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDR4300 Connection is not private, certificate authority invalid
- Mark as New
- Bookmark
- Subscribe
- Permalink
We randomly get the error message "Connection not private" when trying to use the internet through the Orbi network. I can switch to my 2.4ghz access point that is wirelessly connected to the Orbi system and connect to the internet without issue. I can also connect wirelessly to my modem and access the internet fine.
We have an RBR40 with 2 satellites connected. We are on firmware version V2.3.1.58. My laptop is Windows 10 and is up-to-date.
The problem also occurs on some of our Android devices -- all of which are up-to-date.
Sometimes, rebooting the Orbi system fixes the problem for some -- but not usually all -- of the devices.
Is there a solution to this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDR4300 Connection is not private, certificate authority invalid
Is this in regards to a WNDR3400 or the Orbi system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is in regards to the Orbi system; it only happens when trying to connect to the internet while logged into Orbi. It occurs in all browsers. It occurs on all operating system: Windows, Android, and FireOS.
Firmware V2.3.1.58
Netgear modem D2200D
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your modem already has a router built in:https://www.netgear.com/service-providers/products/telco/gateways/d2200d.aspx
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your help. I'll try this when it acts up again.
It's starting working again now without any changes. This equipment is very, very unreliable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's not Orbi, it's the interaction of your modem/router with the Orbi. Having two routers on the same line is mostly the instability. Please configure the modem for bridge mode or try one of the other suggestions. This will fix this issue.
