Reply
Weak Signal to Satellite Right Next to Router!
knewbee
I just purchased the RBK50 router and satellite kit and set it up according to instructions. I'm getting a signal ok to my laptop 10 feet away, speedtest showing 155mbps download and 11.8 upload.
So why is the satellite LED showing amber when it's right next to the router, instead of blue?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Retired_Member
Not applicable
Re: Weak Signal to Satellite Right Next to Router!
How long has it been amber?  Once things settle down, ALL lights should go out.  After about 30 minutes if the lights are still on I would re-boot all.
Message 2 of 4
knewbee
The LED light shut off, so I moved the satellite downstairs and about 10 feet or less from where I was sitting with my laptop and it took awhile, but it's showing blue and I'm getting 188mbps on my laptop about 6 feetl away from that, so I guess it all good to go.
Thanks a lot!
Message 3 of 4
Guru
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Any Wifi Neighbors near by? If so, how many
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1763 views
  • 0 kudos
  • 3 in conversation
Announcements
