Orbi WiFi 7 RBE973
Reply
Weak upload speeds?!
Mgomez85
Apprentice
Have anyone notice a weaker upload speed after setting up this device or is it my isp? Cause my down speed is off the chart! But my up seems to be very inconsistent!
Message 1 of 2
Random12
Apprentice
Re: Weak upload speeds?!
Are you doing a wireless test? Can you also try to plug your device directly into the Orbi Router (using a a wired connection) and repeat? How about if you do the speed test by bypassing your Orbi Router and plugging directly into the modem?
Hope this helps, it would show what kind of impact the wireless vs Orbi itself vs your ISP.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2074 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
