Orbi WiFi 7 RBE973
Reply
Web UI says RBW30 Update Failed, but there is no update available.
jeraboom
Star
I have a system with an RBR50, 2 RBS50s, and 1 RBW30.
When I use the router Web UI to check for firmware updates, it first attempts to download new firmware for the RBW30 and then says "Update Failed".
When I manually download the current RBW30 firmware from Netgear and go directly to the RBW30 and attempt to update the firmware, the UI there says it's already running the current version. (see attached screenshots)
Side note: I see there's an even newer version of the RBR50/RBS50 firmware (2.7.0.70), but it's not being offered to me via the Web UI update function.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router, RBW30|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 33
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Web UI says RBW30 Update Failed, but there is no update available.
Hi @jeraboom and @Tgterm
RBW30 latest firmware v2.6.1.6 has been posted on the Support Site. Here's the link:
https://kb.netgear.com/000062471/RBW30-Firmware-Version-2-6-1-6
Blanca
Community Team
Message 9 of 33
All Replies
Guru
Then no need to update it then. v4 is the most current version.
Message 2 of 33
jeraboom
Star
I should have mentioned that due to the RBW30 having a status of "Update Failed" I was unable to update my other Orbi units without unplugging the RBW30. This is certainly not a good situation.
Message 3 of 33
Mstrbig
Master
Version 2.7.0.70 is actully the newest firmware available for the RBR50 router and RBS50 satellite. You would have to manually download it and install it. If you decide to update, make sure you update the satellites first, then the router.
Message 4 of 33
Tgterm
Guide
Exact same configuration and issue with the RBW30 Update Failed here.  I was able to update my RBR50 and RBS50 by unplugging my RBW30, but has there been a resolution to the Update Failed issue on that satellite yet?  Or, is Firmware 2.5.0.4 for the RBW30 the latest, therefore nothing to fix?  Thanks!
Online Update
Manual Update
Firmware Update
Check if a new firmware version is available on the Internet.
 Model NameDevice NameCurrent VersionStatus
RouterRBR50RBR50V2.5.2.4No new firmware version available.
SatelliteRBS50RBS50 - KitchenV2.5.2.4No new firmware version available.
SatelliteRBS50RBS50 - UpstairsV2.5.2.4No new firmware version available.
SatelliteRBW30RBW30 - BasementV2.5.0.4Update failed
Message 5 of 33
Guru
V4 is the latest for the RBW. No need for any update. I presume the update services are incorrectly reporting this for the RBW. Should be No Update Available. Maybe a forum moderator and check on this.
@Blanca_O
Online Update
Manual Update
Firmware Update
Message 6 of 33
Tgterm
Guide
Thank you very much for confirming.  Would be nice if Netgear fixed this, though.  Makes updating the firmware on the router and other sats a bit of a PITA.
Thanks!
Message 7 of 33
Guru
Im sure they will...Just skip it for now.
Message 8 of 33
Blanca_O
NETGEAR Moderator
Blanca
Community Team
Message 9 of 33
Tgterm
Guide
Update still fails when I try to perform an automatic update through the router UI.  Can you please remind me of the method to update the RBW30 manually, if that is what you are saying we need to do?
Thank you.
Message 10 of 33
Guru
Do you have access to the RBWs web page? Look for the IP address on the RBRs connected devices page. Use the IP address given to the RBW to access it's web page. Log in will be same as RBR.
Message 11 of 33
Tgterm
Guide
good thought, except the RBW30 does not accept the password I use to gain access to my RBR50.  I even try the default password, and no joy.  One hurdle after another.  Any thoughts on how to reset the RBW30 password or why it does not accept the password from my RBR50?
Thanks!
Message 12 of 33
Guru
Check the user manual for password defaults...
Try a factory reset with the RBW and re-sync it to see if it will connect and the the admin and PW from the RBS50...I believe it should
Message 13 of 33
Tgterm
Guide
So, I have reset it and resynced it multiple times, still will not accept the RBR50 login credentials.  I am a little skeptical of the reset, tbh.  When the RBW shows up in my connected devices again, it still shows up with the label 'RBW30-Basement'...something I had renamed it to.  If it were a true reset, shouldn't it lose that label?
Not sure what to do at this point.  Can't get firmware update access to my RBW30...
Message 14 of 33
Guru
Did you remove it from the RBR after resetting it?
Ya, the reset should clear things however if it resynce with the RBR the RBR may hand off the same config again...
Message 15 of 33
Quincy56
Tutor
The file type that is included in that zip file is a .chk file.  The update option in the GUI wants a .img file.
Message 16 of 33
Guru
What happens if you change the .chk to a .img?
@Blanca_O
Message 17 of 33
Quincy56
Tutor
I was afraid that I might brick the satellite 😞
Message 18 of 33
Guru
It will either load or show same error message.
Message 19 of 33
Guru
I see all prior versions of FW builds are all .chk
What browser are you using?
Try IE11, Edge or Firefox...
Message 20 of 33
Quincy56
Tutor
GUI says the correct file format is .img if I use Chrome, Edge or IE11
Message 21 of 33
Guru
Hmm...try changing the .chk to .img and see. If nothing works, make contact with a forum moderator on this.
@Blanca_O
Message 22 of 33
Quincy56
Tutor
Renamed the file to .img now I get this:
Message 23 of 33
jeraboom
Star
Pretty sure the RBW takes .chk files, and the RBR and RBS take .img files. Maybe you're trying to upload to the wrong unit? Are you connecting directly to the RBW's IP address?
Message 24 of 33
Quincy56
Tutor
I'm using the main router's interface.
Message 25 of 33
Top Contributors
Discussion stats
  • 32 replies
  • 7293 views
  • 4 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
