Reply
What happened to firmware 2.3?
johnny5126
The other day I upgraded my RBR50, RBS50 & RBR40 to firmware 2.3.0.32.  I had to use the 2.2.1.212 update first on the RBR50 to update to 2.3 and got it from on here on a dropbox account.  Now when I look, it's gone and 2.2.1.210 is back as the latest update, and the 2.3 is gone.  Was this a bad update?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only), RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 9
Guru
Re: What happened to firmware 2.3?
v32 is there:
https://www.netgear.com/support/product/RBK50.aspx#download
at the top of the support page.
"Top Support Articles
RBR50 / RBS50 Firmware Version 2.3.0.32"
All 20 and 40 Series can be found here:
https://community.netgear.com/t5/Orbi/New-NetGear-Orbi-20-40-Series-Firmware-Version-2-3-0-28/td-p/1...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 9
johnny5126
Its not there for the RBR50.
Message 3 of 9
ekhalil
Master
Please use the pages for RBR50 and RBS50 instead:
RBR50: https://www.netgear.com/support/product/RBR50.aspx#download
RBS50: https://www.netgear.com/support/product/RBS50.aspx#download
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750, Wired/Wireless Backhaul / Orbi RBR50 + 6x RBS50 + RBS40V, Wired/Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 4 of 9
Guru
It's there...
Message 5 of 9
tagteam
Virtuoso
Does anyone know what the deal is with this image? I type in "RBK5" and get all of the variants with each having a version with "NETGEAR Armor" and another without.
Each obviously takes you to the download page for the firmware downloads. Is there a difference?
Message 6 of 9
Guru
NO FW difference. Just the K means Kit and each Kit has either 1 or 2 satellites in the box.
FW is the same for the 50 series systems.
https://community.netgear.com/t5/Orbi/New-NetGear-Orbi-Firmware-Version-2-3-0-32-now-available/td-p/...
Message 7 of 9
tagteam
Virtuoso
Thanks, Furry. You have to admit those entries are a bit confusing, though.
If users enter "RBK53", they're going to have to choose between two entries, one for Armor and one without, and how are they going to know those two are exactly the same?
I think Netgear needs to eliminate one or the other if there is no difference between the two.
Message 8 of 9
Guru
I agree, not very informative on what is the difference. I see the file size is the same for v32 between the Armour and Non Armour versions.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1415 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
