Reply
What is a compatible replacement for RBR40 so I can use existing satellites (RBW30)
tonyg617
Follower
I had the RBR40 main unit fail hardware (the pinhole reset broke when I was trying to reset after a failed firmware upgrade)
The unit is out of warrranty.  It seems a shame to lose use of two perfectly fine satellites.
Question:   What main units are compatible wiht RBW30 satellites that I can buy just the main unit?
Message 1 of 2
Guru
Re: What is a compatible replacement for RBR40 so I can use existing satellites (RBW30)
RBR 20 and 50 series. RBWs are not compatible with Orbi AX systems.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 112 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
