Discussion stats
  • 33 replies
  • 36383 views
  • 6 kudos
  • 12 in conversation
Announcements
Top Contributors
Reply
Highlighted
Apprentice
Re: What is the highest speed that the Orbi's can handle?
MacBookPro (late 2013), speedtest history when connected on Satellite RBS 50, wireless backhaul betwen RBS 50 and RBR 50, RBR 50 acts as AP mode to the main Router given by ISP, I am with 1Gbps Fibre plan.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 26 of 34
Highlighted
Master
@sh2sg Is that with the Macbook wired to the satellite?
Message 27 of 34
Highlighted
Apprentice
No, it is always wireless to satellite.
Message 28 of 34
Highlighted
Master
OK. Very impressive results.
Message 29 of 34
Highlighted
I thought long and hard about whether I wanted the RBK40 or the 3.0 Gig AC3000, but I settled for the AC2200 because Best Buy had a 3 satellite package in stock when I was in the store today.  Yeah, I could have just ordered the AC3000 off of Amazon (and may yet...), but I am replacing a Linksys Velops that was literally getting 10 megs and below in two of the APs.  And my service is a gig.  So, yeah, I was pissed.  In any event, I set up the AC2200 this afternoon and am consistently getting @500 megs across two of the three AP.  The third, I eventually put in my attic and it serves the bedroom over the garage (about a 3500 sq ft house, so not huge).  That third access point gets about 125 megs.  It works, but I'd be pissed if that's the wifi bandwidth I was getting.  I know, I know, a lot better than those 14.4k modems we used to use.  In any event, in most places in the house (and all of the places I'd want connectivity), I'm getting about 500 megs.  The main bedrooms, the family room, the pool area, all @500.  The Orbi is about 10,000x better than the Velops.  Which is strange, as the reviews are basically on-par between the two of 'em.  I've literally spent 6-8 hours on the phone with Linksys technical support over the last month.
In any event, this is what I'm getting:
Model: RBK40| Orbi AC2200 WiFi System
Message 30 of 34
Highlighted
The prices you pay are insane! Don't complain. In AZ we pay $70pm for 150mbps down/10up from COX!  $59.95 for 1GB FIOS is a steal and $29.95 for 100/10 is unreal.
Message 31 of 34
Highlighted
Omg. Someone clearly didn’t know how to use their MacBook! 😄😄😄
Message 32 of 34
Highlighted
ooohhh boy that was a read!
I understand your frustration about the 1 Gbps plan not actually giving you 1 Gbps performance.  Ive been there until I realized that the hardware in the devices was the limiting factor, doh!!
You'll never see 1 Gbps on you cell and laptops for wireless performance unless you had a way to directly wire the device such as an ethernet cable.  The most ive ever seen is 250ish Gbps which is still amazingly fast and above the next tier down offered by FioS.  My PC sees 1 Gbps performance with a direct connection and so does the Xbox one X to a degree....  (I have a network MoCA extender by the TV and Xbox to get an ethernet connection but Xbox Live service limits data transfer rates severely...  I see like 350 Mbps max).
The real benefit to Gigabit internet is to be able to saturate your network with wireless devices (laptops, cell phones, tablets, Amazon Echos, security camera systems, all other wireless devices) without seeing a dip in performance on any device.  I think the 100 or 150 Mbps plan would still work for me but while I have a discount, I will keep trying out the gigabit.
One thing I noticed is alot of early "smart TVs" came with crappy antennaes.  They could only see 2.4 Ghz and would read no more than 5-10 Mbps for streaming purposes where as my phone in the same room would see 100 Mbps.  wild.  How you going to get away with streaming 1080p on 5 Mbps..  that will cause quite a few lags in the video playback.
Message 33 of 34
Highlighted
Guru
The Orbi theoretically should be able to handle 1000Mb on the WAN to LAN since all RJ45 ports are 1000Mb supporting. The wireless speeds will never see much over 400-500Mbps depending upon wireless client HW and Mfr design.
Testing of a 50 series RBR has not seen anything near 900Mbps on the WAN to LAN side tests with a wired PC.
This issue has already been reported to NG for review:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-is-not-supporting-900Mb-on-the-WAN-to-LAN-test/m-p/...
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.15.32(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 34 of 34
