- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What the Hell is a Dos Attack
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an orbi rbr 50 as my router connected to an xfinity modem, we have the fastest internet available from them yet I get constant slow downs when downloading from any game service many times. There's usually at least 8-10 devices connected total and we have one orbi satellite for the security cameras and laptop in the front of the house. And being curious as to what is going on I found the router logs on the portal, and have no idea what to make of it. Anyone have a clue what the hell all of these dos atttacks are?
log is in this pastebin: https://pastebin.com/Zb5BzThQ
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What the Hell is a Dos Attack
https://en.wikipedia.org/wiki/Denial-of-service_attack
Use this tool to look up those IP addresses. You may need to ask your ISP for some help on this if your getting attacked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router has the latest firmware, V2.3.5.30, and the isp modem is the Xfinity xFi Advanced Gateway and the model # is: CGM4140COM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem/Gateway Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
My orbi router is currently on router mode and the modem is already in bridge mode with wireless turned off, should I still turn on AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can try this. Would mean that the modem would not be passing thru any DDOS attacks and not be come the attacked unit.
See if this changes anything...something to talk to your ISP about. See if they can give you a different WAN IP address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do a full power OFF then back on with the RBR. Leave the RBS off for now. Ensure your RBR is connected with the WAN port to the LAN port on the ISP modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@christianjb wrote:Anyone have a clue what the hell all of these dos atttacks are?
Others are helping with the performance issue. The term "DoS" stands for Denial of Service. The Orbi firewall detects when the same IP address sends a number of similar packets which could be interpreted as an attempt to "flood" the Orbi to the point that it is unable to respond. e.g. Denying the router the ability to perform service. The Orbi firewall discards all of those packets and puts an entry in the log.
Occasionally, the news will report that somoe group of hackers has attempted a DoS attack on some entity, such as by using thousands of "bots" to bombard Google (or someone) with email or web requests in an attempt to force them out of service.
NOTE: if some "evil doers" REALLY performed a DoS on an Orbi, then performance would drop to nearly zero and remain that way until they quit. I have accumulated all of my Orbi log files since March. Every month there are dozens and dozens of these reports, yet my Orbi works fine.
These DoS entries are normal. They are not related to your issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
