gjbarton's avatar
May 01, 2018
What values can "backhaul status" have?
I've seen Backhaul Status with the values "Poor" and "Good".  Are these the only options?
The manual is unhelpful on this.
Thanks,
Geoff.
    • gjbarton's avatar
      gjbarton
      Tutor
      Not sure I understand your reply.   I think Part 1 is missing?  Sorry, new to this system - I see part 1 was my question.
      Still don't understand your reply though.  Just a list of your kit.
      Thanks,
      Geoff.
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Yes these are the two options with good represented with a Blue light and poor with a amber light on the satellite.
        DarrenM
  • Per /www/DEV_show_device.htm, it can be 'Good', 'Poor', or 'Config Sync'.
