Orbi WiFi 7 RBE973
Reply
What you can expect with your Orbi system
Bsbrady
Initiate
Re: What you can expect with your Orbi system
I disagree with a minor issue. I work from home and cell reception is bad so I use WiFi calling on my iPhone as my primary phone. So disconnects are a major issue. I have lost phone calls and dropped from conference calls. Not good. Just got my system last week. Got it from amazon do returns are good. I’ll give it another week and the. Goodbye
Message 51 of 52
Guru
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Message 52 of 52
Top Contributors
Discussion stats
Announcements
Orbi WiFi 7
