× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 8 replies
  • 2009 views
  • 1 kudo
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
WhatsApp messages not delivered
We have found that when the Orbi is in router mode that WhatsApp messages to some devices are not delivered. The notification arrives on the phone saying “You may have new messages”, but the actual messages themselves cannot be delivered until the phone is disconnected from the WiFi. Switching the orbi to access point mode resolves the issue, but this is not really the solution that I want since I lose a lot of other functionality with this. The affected device is a Nokia TA-1012, but as above it works fine with orbi in AP mode or when it is connected to mobile data, any idea what could be causing this in router mode?
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 9
Accepted Solutions
Highlighted
Re: WhatsApp messages not delivered
Oh my. Finally figured it out! My wife’s phone was incorrectly tagged as belonging to my children in the Circle parental control application, totally my fault! Assigning it back to her with no parental controls has fixed it, so sorry for wasting people’s time.
Message 8 of 9
All Replies
Highlighted
Master
It seems that your ISP router is acting as another router in the network.
If you want to keep Orbi in Router Mode you need to bridge your ISP Router, otherwise you have to have Orbi in AP Mode.
Please try to bridge the Router (check the ISP Router manual how to do it) so that you can keep Orbi in Router Mode and make use of all the Orbi Router functionality.
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 2 of 9
Highlighted
Guru
Is the Orbi system operating in Router or AP mode?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
My Setup (Cable 900Mbps/50Mbps)>CM1100>Orbi RBK50 v2.5.1.16 and Orbi RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK852, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 3 of 9
Highlighted
It’s a Plusnet Hub One ( don’t have the exact model to hand at the moment as I am away). It looks like there is no bridge mode supported in it unfortunately, so i will give option 2 a go (option 3 works for me, but I lose router functionality such as parental controls). I think the other option would be to buy a cheap modem that does support bridge mode, thank you so much for all your help - I tried to go via support but actually got no response in several weeks!
Message 4 of 9
Highlighted
Guru
Ok, give option 2 a try. WIll probably help it.
It's preferred to get a modem only unit with no built in router, if your ISP supports those kinds of modem if your going to use a external router like Orbi.
Good Luck.
Message 5 of 9
Highlighted
Ok, so replace the plusnet hub one with a net gear dm200, had no end of trouble setting this up but eventually have it functioning in modem only mode and have switched the router functionality back on on the Orbi, and still the same result! It only affects one phone, but it’s my wife’s and not getting WhatsApp messages is a real problem! Feeling quite frustrated Smiley Sad
Message 6 of 9
Highlighted
Guru
If other devices are working and the one app on the one phone isn't, there mabye a problem at the phone or with this app.
You might try WhatsApp support to see if there is any information on why messages are not getting delivered.
Try removing the app, hard reset the iphone, power pack on, then re-install the app.
Try setting manual DNS on the Orib router to see if this helps, try 1.1.1.1 and 9.9.9.9
Message 7 of 9
Highlighted
Message 8 of 9
Highlighted
Guru
Glad you figured it out. I should have asked about Circle. Glad you got it working. Mark this as solved so others will know what to check for.
Enjoy. Smiley Wink
Message 9 of 9
