- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Which Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which Orbi?
Hello, I have a standard fibre connection into the house (with Virgin Media) and currently running my computer in the office from a hardwire connection, having recently run a CAT7 connection. I want to move the end point to an Orbi given reviews but I don't see the need to replace the main modem- is this possible - hardwire connection from Orbi access point - therefore connecting my laptop in the office (and surrounding area) via wireless?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Which Orbi?
I'm not sure that I follow all that. Needs sentences to break the bits apart so that I can see what is going on.
As I understand it, the answer to the question "is this possible" is yes.
Here's what I have: modem>router>Orbi.
The Orbi connects to the router over Powerline Ethernet, effectively a wired connection.
The Orbi is in AP mode.
The unknown is your modem. Is it really a modem/router rather than a plan modem? If it is a modem/router, then the options are to put it into bridge (modem only) mode, or to put the Orbi into AP mode.
You do refer to "Orbi access point" but does that really mean AP mode?
This bit is puzzling:
What is hard wired to what? You can certainly use the LAN ports on an Orbi router to wire in a laptop.
But what about the connection between the Orbi and the modem? Isn't that what you want to use to wire the Orbi back to?
Like I said, I'm a bit confused. Maybe it is because I have been in quarantine for too long.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Which Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Which Orbi?
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@mrchrise wrote:Hello, I have a standard fibre connection into the house (with Virgin Media) and currently running my computer in the office from a hardwire connection, having recently run a CAT7 connection. I want to move the end point to an Orbi given reviews but I don't see the need to replace the main modem- is this possible - hardwire connection from Orbi access point - therefore connecting my laptop in the office (and surrounding area) via wireless?
