Reply
Which extra extender to get for an Orbi RBK53?
Commodore
Initiate
I have an Orbi RBK53 with 2 satellites already and need to get an extra satellite for a new property extension. Which sattelite/extender should I get?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Guru
Re: Which extra extender to get for an Orbi RBK53?
Many would work. It all depends on what you need.
you can use:
rbs20
rbw30
rbs40
rbs40v
rbs50
rbs50v
just keep in mind the 20-40series are only the 866mbps backhaul.
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 4
Commodore
Initiate
Thanks, I'll go for the RBS50, same type as now.
Message 3 of 4
Guru
Also EX7500/7700 work as well.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 201 views
  • 2 kudos
  • 3 in conversation
Announcements
