- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Which product would I get w an ethernet port to connect to a console that can pair with my Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBR40 — Orbi AC2200 Tri-band WiFi Router with a satellite that plugs directly into the outlet, but it does not have an ethernet conection capability.
Do I have to spend several hundred again to just get a satellite w that ability?
Thank you!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Which product would I get w an ethernet port to connect to a console that can pair with my Orbi?
the satellites with ethernet ports are:
RBS20
RBS40
RBS40V
RBS50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, much appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MarkM13 wrote:Which product would I get w an ethernet port to connect to a console that can pair with my Orbi?
There is another solution, a Netgear EX3700 WiFi Extender ($25US on Amazon)
This does not enlarge the Orbi WiFi coverage area. It merely connects to the Orbi WiFi (actually any router's WiFi) at either 2.4G, 5G, or both and has one ethernet jack that can be used to support one device (or a switch).
Actually, any brand of WiFi extender with an ethernet jack will do the same thing.
