Orbi WiFi 7 RBE973
Reply
White Light Flashing
Frustrated7476
Follower
This device is the biggest piece of junk and ive never dealt with worse service than netgear.  my router works fine, and then after a month of use the satellite stops working, with a flashing white light on the top.  I spent hours with tech support and reading forums and despite many other people having this problem there is no solution.  finally they sent me a replacement, and the replacement has the same problem.  now they are sending me another replacement which means the original has to be returned, which may take a week altogether.  im here praying for a miracle, that someone has an idea that wasnt covered in my 8+ hours of tech support.  thank you kindly.
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 2
Guru
Re: White Light Flashing
If they sent you a RMA already and it does the same thing, seems like it's not a Orbi issue, rather a configuration or environment issue.
Which model Orbi system do you have?
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 474 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
