- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Whole set up keeps rebooting every hour or so
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware 2.1.1.12 on bother Router & Satellite
Every hour or so, the router just drops connection. I take a look at it & the Satellite is pulsing purple, and the router is just restarting.
Is there a fix to this?
Also, I’m having a problem with consistency.
My ping will be something like this...
30ms
30ms
30ms
500ms
30ms
Repeat
Why? What’s the deal with this? I thought this new firmware would fix things, but clearly not.
If anyone knows how to fix this garbage, I would be greatful. I’m really fed up with this thing. A $400 paperweight.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Whole set up keeps rebooting every hour or so
First, I'd suggest update to firmware 2.1.1.16, it doesn't specifically address issues that you are having but I don't think it's any worse and .12 was. I have been running it for a week without issue other than the display issues.
Also the upgrade process itself may fix some of the issues - I've found that just re-applying the same firmware over top of the existing sometimes fixes stability. They are not pushing it so you have to download then update - first the satellites - one by one and then when those are up then update the router.
What are you pinging that is 30ms? When I ping google.com I get pretty consistent 16-17ms.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m really just done with this thing. I don’t think I’ll ever buy anything from Netgear ever again.
And I am Pinging Google as well. Here’s my results;
- Mark as New
- Bookmark
- Subscribe
- Permalink
I pay for 250 download & 15 upload.
LOL I hate this Router. So much.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have 25% packet loss on your network - that is beyond horrible when it should be 0%. You need to get someone to figure out what is causing that on your network. Either cross interference with some other network, something on your network going berzerk, or just bad hardware - but you need someone with some tech troubleshooting skills there. It's difficult to fix this kind of thing over email.
- Mark as New
- Bookmark
- Subscribe
- Permalink
