Reply
Highlighted
Follower
Why would Orbi system keep loosing it connecitivity
I purchased my Orbi (RBK-43-200NAS) a few days ago as I was told it was very easy to setup. well I followed the easy to set up instructions yet, my system is constantly loosing connectivity. If you don't have a teenager in the house be glad, because its a bad situation when they have no internet. what type of garbage did I buy Netgear?
Message 1 of 3
Highlighted
Guru
Re: Why would Orbi system keep loosing it connecitivity
What do you mean by lose connectivity? Wireless and wired?
What is happening when this appears? Need more information to help you out.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
My Setup (Cable 900Mbps/50Mbps)>CAX80(Modem Mode)>RBK853 v3.2.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Highlighted
Guru
Well, this isn't helping us much to help you. Details will help us to help you out.
1. What modem are you using (model number, firmware)?
2. What firmware is on your router and satellites?
3. How large of an area are you attempting to cover?
4. how far apart are the router/satellites? They need a minimum of 30ft or they'll have issues.
5. what is your house made of and can you move stuff around a little? Hvac, plaster lathe, foil lined insulation, brick, concrete, all do a great job of blocking wifi signals. This makes the wireless backhaul unstable. If its HVAC blocking signals, sometimes moving stuff around a bit helps.
6. When you say your system looses connetivity, what do you mean exactly? Is your wireless signal disappearing, your satellites not connecting, "internet not available messages", what exactly is going on?
Again, details help us. Go into detail about the problems, what equipment you're using, the environment. The more we know the more we can help you. Orbi is pretty simple once its setup, updated, and configured properly. its as close to set and forget that I've used.
CM2000-> Arris AX11000 W31-> GS716v2-> WAX***-AP
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 220 views
  • 0 kudos
  • 3 in conversation
Announcements
