- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wi-Fi speeds Not as Advertised?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased the RBK53 system (RBR50 plus two RBS50 satellites). I added two additional RBS50 satellites for a total of 4 satellites. The install was successful with all components listed in Orbi Network map and device manager. Speedtest for wired connection is 400+ Mbps (I have a 400Mbps up / 10Mbps down broadband plan) Speedtest for Wi-Fi connection is only 93Mbps down / 10Mbps up. Shouldn't this mesh Wi-Fi system that advertises 3Gbps Wi-Fi speed capability provide the same 400up/10down for wireless connections as wired? Is the RBK50 system needed for faster Wi-Fi speeds? A comparison of the two systems appears to indicate that the RBK53 I purchased is better with 6-antenna satellites rather than the RBK50 satellite's 4-antenna config. The only RBK50 feature missing on the RBK53 is Alexa cvompatibility if I'm reading the specs correctly.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Finally tracked down the issue. Bad Orbi included cat5e cable. Swapped it out for a cat6 cable and the ISP modem hardware LAN port immediately auto-negotiated to 1000Mbps. Physical layer 1. Should have started there rather than layer 4, 3, 2 ... Basic networking 101 failure on my part. In my defense - network training was over 20 years ago 🙂
Now getting my full 477Mbps download speeds on all gigabit-enabled devices I've tested so far
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wi-Fi speeds Not as Advertised?
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What wireless devices are you using to speed test with?
Try speed testing with just 1 satellite connected at 30 feet in between the base and satellite. Be sure to turn OFF the wifi on the mobile device, move close to the satellite, then turn ON the wifi on the mobile device, then speed test.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded? v2.2.1.210
What is the Mfr and model# of the ISP modem the NG router is connected too? Arris TG1682G
Router operating mode
MBA13 / Gigabit ethernet / 802.11ac / osX v10.14.3 + 2019 iPhone Xs Max / iOS v12.1.4
Try speed testing with just 1 satellite connected at 30 feet in between the base and satellite. Be sure to turn OFF the wifi on the mobile device, move close to the satellite, then turn ON the wifi on the mobile device, then speed test. 81 down / 9.5 up on Satellite-4
What is the size of your home? Sq Ft? 1915 sq ft
Home is constructed with 16-inch off-center 2x4 framed / drywall covered interior walls
Satellite-1 is 40-ft from RBR50 open area (few obstructions between)
Sat-2 is 15-ft from RBR50 / bedroom - wall between
Sat-3 is 22-ft from RBR50 / bedroom - wall between
Sat-4 is 30-ft from RBR50 / garage - wall and door between
2 satellites are closer than 30 feet from each other / 20ft apart - wall between
Current
2.4Ghz = Auto ( 8(P) + 4(S) ) / up to 400 Mbps mode
5Ghz = 36+40+44+48(P) / up to 866.7 Mbps mode
Changed to:
2.4Ghz = 1, 4, 6, 11
5Ghz = 36, 40, 44
Any Wifi Neighbors near by? If so, how many? No
What WPA security modes are you using? WPA2-PSK (AES)
Try enabling Beamforming and MIMO Completed
Above setting changes completed and tested
None of the above setting changes had any effect on Wi-Fi speeds but did cause the Orbi router to be no longer accessible by entering its IP address in the browser URL
The RBR50 Orbi router is directly connected to the ISP modem. A speed test when wired directly to the RBR50 Orbi router was 90 down / 10 up. Same speed as all wi-fi connected devices irrespective of age. Seems like the limitation is between the modem and Orbi router connection
Speed tests returned 477 Mbps down / 10.5 Mbps up when wired directly to the ISP modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suggest updating that firmware to the newest release (.38). You will probably enjoy higher backhaul stability as well as a few other perks. Very important for your setup considering the number of satellites you have.
You can search for the downloads for the firmware on here.
Upgrade the satellites (all of them) first.
Upgrade the router to the intermediate firmware first and then upgrade the router to the final version (.38)
Let us know if you have any questions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah yes, bad lan cable. Some in box cables are not the greatest. Cal the new cable fixed this.
Please update to v32 when you get a chance:
Update the satellies FIRST, then the RBR lastly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I check for FW updates in the Orbi app or logged in online it indicates it's up to date and there are no new FW releases
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please check the NG download site for updates.
https://www.netgear.com/support/product/RBK53.aspx#download
