Reply
Wi fi drops
iancooke101
Initiate
Wi fi drops
Hi, pretty new to this so hoping you can help. I've installed the Orbi and all appears to be fine except the wifi connection from the Satellite is ridiculously intermittent. Quite literally will switch from download speeds of 50mbps to 5 to 25 to dropping off completely to going back up to 45. Is there any way I can do something to create a more stable connection? My son is going mad as every few minutes his Xbox live drops completely so he's in and out of games, losing his connection. Really frustrating. Thanks in advance,
Ian C
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 4
DarrenM
NETGEAR Moderator
Re: Wi fi drops
Hello Iancooke101
You can try to adjust the wireless channel in the wireless settings you may also want to try and move the satellite a little closer to where the main router is.
DarrenM
Message 2 of 4
iancooke101
Initiate
Re: Wi fi drops
Thanks for your reply. Logistics of the house mean they are as close as they can be. Light comes on blue so I'm assuming the proximity between router and satellite is ok. In terms of adjusting wireless channels do you mean set the Orbi to channel 1,6 or 11 via admin settings and / or on my BT broadband router which in turn connects via Ethernet to the Orbi router? Not sure if I need to change channel settings on both? Thanks.
Message 3 of 4
DarrenM
NETGEAR Moderator
Re: Wi fi drops
Hello iancooke101
you would just need to adjust the channel on the orbi.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1943 views
  • 1 kudo
  • 2 in conversation
Announcements
