- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi Mesh
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wifi Mesh
SO I have poor wifi speed due to a high density of routers in the area. I pick up at least 11 wifi signals. Will putting in an Orbi system help with this. curious before I purchase anything. I have tried changing chanels and it does not help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Mesh
@Ponxs wrote:SO I have poor wifi speed due to a high density of routers in the area. I pick up at least 11 wifi signals. Will putting in an Orbi system help with this. curious before I purchase anything. I have tried changing chanels and it does not help.
I doubt your speed issue is due to your neighbors specifically.
The Orbi does offer a more robust wifi (MESH) network over the standard when used with a Sat. Even so, setting the wifi channel to AUTO is your best bet. Setting your wifi channel to a specific channel in most cases is a waste of time for chances are your neighbors are doing the same.
Wifi speed has many factors involved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Mesh
You can turn down the power output of the wifi radios on your current router to see if this helps any, if your router supports this. Helps in reducing the interferences seen when in a wifi congested area or environment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Mesh
This article explains why WiFi can be a poor choice due to co-channel interference.
Certainly worth trying to turn down the signal strength of your WiFi radio, if possible. However, the other WiFi signals may "drown" yours out depending on their relative strength. Best bet is to hard wire with ethernet cables. Good luck!
