- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi Off every 5 mins !!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just bought RBK53, WiFi signal is turning OFF and ON every 1-5 sometime every 45 minutes and I don't no what's the solution.
Firmware Version V2.2.1.210
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Off every 5 mins !!
Do a factory reset on the system and setup from scratch. If it still continues,
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highligh...
@Zuhair2008 wrote:
Hello
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Zuhair2008 wrote:
Hello
What wired devices do you have connected to Orbi? Any mesh speakers (e.g. Sonos)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing changed ..
@Zuhair2008 wrote:
Hello
- Mark as New
- Bookmark
- Subscribe
- Permalink
My connection is Fibre .. I'm using Huawei EchoLife HG8245Q , there are two devices connected to it
Wired :
1- Huawei EchoLife HG8245Q --> RBR50 .
2- Huawei EchoLife HG8245Q --> TP-Link Powerline 1 --> connected to TP-Link Powerline 2
nothing wired connected to RBR50
@ekhalil wrote:
@Zuhair2008 wrote:
Hello
..What wired devices do you have connected to Orbi? Any mesh speakers (e.g. Sonos)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Wired :
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried step 3.. Nothing changed.
Is there anyway to make two different ssids names? One for 2.4 and the other for 5.0 ? Maybe this step will fix the problem.
@FURRYe38 wrote:
Modem Combo Units:
Couple of options,
Wired :
- Mark as New
- Bookmark
- Subscribe
- Permalink
Separating SSIDs is not supported on the orbi, though there is a couple of threads regarding users separating the SSIDs on the Orbi.
You shouldn't have to do this however.
You sure the Wireless is disabled and fully OFF on the ISP modem?
Any other wifi sources near by?
What happens if you turn down the wireless power output on the radios, found under Advanced Tab/Advanced/Wireless settings?
Also set a manual channel 1, 6 or 11 on 2.4ghz.
I presume nothing works to help this, you may have a bad system and would need to be RMAd.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you please test to set Orbi in AP mode and see if this will give any improvement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think they have already tried that...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I changed the channel from auto to 11.More than 3 hours everything working great .. if the problem still there I will inform you.
Thank you for your support
Can I ask you what do you mean with RAMd ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think that this is part of the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad changing channels helped. Sounds like there maybe some 2.4Ghz wifi interferences on the other channels.
Enjoy.
