Reply
Wifi connection monitoring software
georgengan
Star
Hi all
While there are ongoing discussions regarding the stability issue of Orbi (me included), it seems most discussions are based on perceptions from some specific events which may or may not be related directly to the Orbi setup. Is there any wifi connection monitoring software (MacOS in my case) that anyone can recommend so that I can just turn on 24 hrs monitoring and objectively observe whether there is a pattern for those dropped connections?
Thanks very much!
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 3
georgengan
Star
Re: Wifi connection monitoring software
Because I can compare the downtime, connection speed, etc with those data reported by my BT SmartHub (or whatever the service provider's hub is) and see wether the slow-down/disconnection is related to the broadband provider or orbi. I am not an expert so these are just my naive thinking.
Message 2 of 3
Bing-Stroller
Luminary
georgengan,
So simple yet brilliant Smiley Happy
Thanks, just off to find my hubs login details.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 594 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
