Discussion stats
  • 2 replies
  • 280 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Wifi coverage problems with the Orbi AC3000
I have Verizon Fios 1gbit connection deal and connected a netgear mesh system. There is the main router in the center room of the first floor and 2 orbi extenders (one in the basement and one on the 2nd floor). We live in a less than 2,500 sq area but the signals on the second floor are more than horrible. Any help would be great.
Nina N.
Message 1 of 3
Highlighted
Guru
Re: Wifi coverage problems with the Orbi AC3000
Is the Orbi system operating in Router or AP mode?
Are you getting to spec speeds with a wired PC?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK853 v3.2.15.2#(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Highlighted
Luminary
I have often wondered about coverage in multi-story houses.
If you think about the wireless signal it's a dounut shape with the weakest signal directly above and below the donut shaped field.
But, I believe, the Orbi has multiple antenas and I'm not sure of the orientation of them but, nevertheless I think the signal will still be poorest imediately above and below the router and satelite.
You would also need to concern yourself with distance between the devices as you change horizontal position of the devices since distance is also a factor.
I think position of the devices is very important and some trial and error is needed to find the best locations for each of the devices.
Ian
Message 3 of 3
