- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi for at LEAST Gigabit throughput?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Upgrading my 1,200 sq ft home to Gigabit internet. While most routers can handle 1Gigabit speed when hardwired, which mesh system do you recommend that would be able to have at least 1 Gigabit WiFi throughput speed to get the most out of the new speed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi for at LEAST Gigabit throughput?
This table should give you an idea regarding NG mesh offerings. Only RBK852 supports Gigabit WiFi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
An ambitious goal, but perhaps not practical. When I look at articles describing WiFi "speed", it appears that the only systems that will support gigabit (in any fashion) are WiFi 6 systems. Here's an article going through some of the factors:
https://dongknows.com/wi-fi-6-explained/
I think the concensus is that the current Orbi WiFi 5 product:
- Struggles with a gigabit internet connection (Orbi was submitted to the FCC in 2016 when 100mb internet connections were only a fantasy, let alone gigabit).
- Supports a maximum theoretical WiFi 5 (AC) connection of 433mb.
So, if this is truly what you are looking for, then your search should be confined to the "Bleeding Edge" products from the various vendors. Would be worth time spent to read through the user forums of the current WiFi6 products, including Netgear's two WiFi 6 product lines:
Orbi (AX) https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax , and
Nighthawk https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
I have absolutely no clue which vendor (or which of their products) will emerge as the industry leader or "best buy".
My bottom line, this may be a time to "put something in" and plan to replace it in 2-3 years.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also be aware that not all wifi devices support seeing any thru put speeds near 900Mbps. Most max out at around 400-500Mpbs. Check with your devices Mfr on what they support on them.
If you have any AX supporting devcies, then maybe Orbi AX is something you should look into.
@BrMcC wrote:Upgrading my 1,200 sq ft home to Gigabit internet. While most routers can handle 1Gigabit speed when hardwired, which mesh system do you recommend that would be able to have at least 1 Gigabit WiFi throughput speed to get the most out of the new speed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Galaxy S10 and wife's S10+ have AX. My daughter's iPhone 11 has wifi 6. So yes, there are clients that should theoretically support 1Gbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something to look into.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's a good site that explains Wi-Fi networking and cuts through the speed hype that's typical with nearly all of the vendors. https://www.duckware.com/tech/wifi-in-the-us.html#routerhype
Good news is it looks like a new Wi-Fi spectrum will become available in the 6Ghz band (Real Wi-Fi 6). This should cut down on interference, but the race for high speed numbers may end up hogging up the new band just as in the current 2.4 & 5Ghz bands.
On the bright side there are new modulation scheme standards coming with it, that are more efficient, and coexists with others better.
