Orbi WiFi 7 RBE973
Reply
Wifi troubleshoot problems
geeksquadtech
Follower
If you are facing any problem in your home or office Wi-Fi network and need any technical help?
If yes then you can contact to Geek Squad support for help.They have well trained professionals who are experts in all sorts of technology and can solve all your issues regarding your device.
Geek Squad agents will visit your office or home and analyze you wifi network and run an troubleshooting if it works unless they will fix the fault because of which your network is processing slow and verify your connection between devices.
So if you need assistance you can contact to Geek Squad support 24/7 for help.
Model: A6100|WiFi USB Mini Adapter
Message 1 of 2
Re: Wifi troubleshoot problems
Or use the service that Netgear recommends.
Netgear does not provide paid-for support. It farms that out to GearHead Technical Support.
GearHead Support
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 621 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
