Orbi WiFi 7 RBE973
Reply
Wifi works but all other ports do not
jstampfli
I have a good internet connection to the internet but for whatever reason, none of my outgoing ports are working when I directly plug into it. Not sure why that's happening?
Message 1 of 4
Accepted Solutions
jstampfli
Re: Wifi works but all other ports do not
I contacted support and found out the ip address on the satelite was not matching the router.  What I was told to do next is unplug everything coming into the satelite and hold the reset button down for about 1 minute.  Once that was done it hooked up to the router no problem and worked perfectly.
Message 3 of 4
All Replies
QATAR80
I have the same issue with satellite
Message 2 of 4
jstampfli
Message 3 of 4
QATAR80
Thank you so much for the advice
It worked now
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2010 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
