Orbi WiFi 7 RBE973
Reply
Will Orbi RBR40 with 3 satellites work with Starlink modem
Dazmae7
Follower
We upgraded to Starlink (satellite is our only internet option). Equipment arrived and is connected, signal active, I can connect to the internet through the Starlink router. But my Orbi RBR mesh with 3 satellites doesn’t seem to work when connected directly to the Starlink modem the way it did with our ViaSat modem and Hughes before that. Is it not compatible? What is compatible? We have a bigger home with thick walls and need range extenders.
Message 1 of 2
Guru
Re: Will Orbi RBR40 with 3 satellites work with Starlink modem
try putting the netgear in access point mode.
The starlink receiver connects to its own router setup. so it puts you in a double nat (2 routers in router mode on the network)
What is Double NAT? | Answer | NETGEAR Support
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2020 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
