Orbi WiFi 7 RBE973
Reply
Will Orbi be WPA3 compatible?
forman2112
Follower
Looking to purchase the Orbi system for my home, but wondering if it will be WPA3 compatible (when the technology is available) or will I have to buy a new system at that time?
Looking at the RBK50 (AC3000) system.
Thanks!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
guzzijason
Apprentice
Re: Will Orbi be WPA3 compatible?
You may need to buy new hardware regardless if you want WPA3, as the new spec requires hardware certification. However, just speculating. No real technical details for WPA3 have been released yet, so there's no good way to know if (any) legacy hardware will be able to upgrade to WPA3 yet. It's probably just too early to tell yet how this will shake out.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1059 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
