Orbi WiFi 7 RBE973
Reply
Will older satellites slow down my ORBI AC3000?
sabadir
I want to buy a couple more satellites but wow...Netgear is proud of the satellites - surprisingly so since its impossible to get this question answered by people who work there.
If I buy one of the older satellites, will my speed be slower only when I am using that satellite?  Or will the whole system be slowed down?
Thanks
Sam
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Accepted Solutions
Guru
Re: Will older satellites slow down my ORBI AC3000?
Older? How do you mean? All RBS50 are the same. They all have the same front and backhaul speeds.
You can add a RBS20 or 30 series to the system and they won't slow the Orbi system down. The backhaul connection rate is lower than the RBS50, 1733 vs 866 so the 20/20 series RBS will just have a slower backhaul connection rate is all.
Message 2 of 4
All Replies
Guru
Message 2 of 4
sabadir
Thanks...
Message 3 of 4
Guru
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 733 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
