Reply
Follower
Will the Orbi system work in a concrete and steel constructed house on both floors ,
Will the Orbi system work in a concrete and steel constructed house on both floors,Or will the steel block the signals ,This is how most southern european countries build modern houses ,
Master
Re: Will the Orbi system work in a concrete and steel constructed house on both floors ,
Concrete and steel and wifi are not good combinations.  A base router, with wireless Access Points, Ethernet connected back to your Base router is the best solution.
Mentor
[ Edited ]
No wifi router will work both concrete and steel  construction both the concrete and steel will greatly reduce if not stop a wifi signal. That way wired system works better but I seen places that even has a hard time aound 50kw transmitters use by a company to seal steel cable and foam in a sheet of plastic all formed a roll in a few seconds.
Discussion Stats
  • 2 replies
  • 327 views
  • 0 kudos
  • 3 in conversation
Top Contributors
