Reply
Windows 7 sees Orbi rbr50 as Gateway not Router
Sookas63
Luminary
I just set up my Orbi but I'm having problems with my Windows 7 Broadcom NetLink Gigabit Ethernet connection. Windows 7 sees Orbi RBRK50 as Gateway not Router. The Orbi is in router mode not AP. Not sure if there are some settings that I need to change or what. My old ASUS system saw the ethernet cable connection but the Orbi doesn't. The PC is desktop and has no wifi connection.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 5
Guru
Re: Windows 7 sees Orbi rbr50 as Gateway not Router
Nothing worng with this.
Is the system working?
Different router Mfr may setup different lables for there products and how Windows detects them.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem |  Wifi Router Orbi RBK752 (Router Mode), Wired Backhaul and R8500 with Orbi RBKE963 (AP Mode), | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 5
raven_au
Virtuoso
I don't understand what the problem is?
It sounds like the Orbi should be seen as a Gateway (assuming I understand your meaning) in this configuration.
What isn't working for you?
How are you expecting it to work?
Message 3 of 5
Sookas63
Luminary
I want to network with other computers in my home. Right now there is no network and so no sharing of files and such.
Message 4 of 5
Guru
You need to make sure all your Windows PCs are using the same named Workgroup name.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1296 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
