Coffeecup's avatar
Sep 16, 2022
Winfox IT
I've been receiving phone calls the past two days about my Netgear product updates. The caller ID displays shows
Winfox Tech. Does anybody know if this is the " genuine"  tech support from Netgear?  thanks
  • Would NOT be from NG. Avoid answering that call. Block it if you can.
1 Reply
  • FURRYe38's avatar
