Orbi WiFi 7 RBE973
Reply
Wired RBK53 with wired connection to MacBook Pro decreased speed
WS-010
Guide
Hello,
I have multiple Orbi's with fw: 2.7.2.104, all wired connected. 2 Orbi's satellites have also a wired connection, one to a Windows PC and the other one Orbi to a Dell 6000 Universal Docking station and that's connected to a MacBook Pro.
With the wired connection to the Windows PC I do get up to 300Mbps when downloading, which is my internet speed, but with the other Orbi with the wired connection to a Dell D600 I am getting aroung 80~90 Mbps on my MBP.
In the adapter setting on the Dell 6000 (thru the driver on the MBP) I have tested it with autoselect speed and forced on 1Gbps. That didn't help. When I disconnect the cable from the Orbi and put it directly in the D6000, I do get the 300Mbps.
Any idea what I can do to fix this?
Thanks,
WS
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 9
Accepted Solutions
WS-010
Guide
Re: Wired RBK53 with wired connection to MacBook Pro decreased speed
Hello,
I have replaced the Dell D6000 and de MBP and now it is working fine.
Thanks all for the help.
Message 8 of 9
All Replies
Guru
What happens if you swap RBS placement with each other? Does the problem follow?
Message 2 of 9
WS-010
Guide
Thanks for the reply, but no, it doesn't matter which rbk I use, it is slow on the mbp.
Message 3 of 9
Guru
I would look into sometring on the MBP slowing the speed down.
What model is this MBP? 20##?
What OSX version are you using?
Message 4 of 9
WS-010
Guide
It is the latest model, just 3 months old. I will swap it with another one somewhere this week and test it the mbp is the problem or not. Thanks for your help
Message 5 of 9
Guru
Try swapping the USB to ethernet adapter first. I use a 1Gb USB-C to Ethernet adatper on my 2018 and it works well. I see 900Mpbs on my 1Gb service.
Message 6 of 9
Guru
Another thing to try is the Dell dock with the windows pc.
See if its the mbp or the dock thats bottlenecking.
Message 7 of 9
WS-010
Guide
Hello,
Message 8 of 9
Guru
Enjoy. Smiley Wink
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 944 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
