Orbi WiFi 7 RBE973
Reply
Wired connection speed slower than Wifi Speed
SSuffolk
Guide
I just purchased the Orbi Wifi system after having an ASUS AC5300 hoping to get better Wifi range which I did, but the problem is the wired connection download speed while performing a speedtest. I'm getting better results over Wifi than wired, why is this happening?
Wired:
Wireless:
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 4
Accepted Solutions
SSuffolk
Guide
Re: Wired connection speed slower than Wifi Speed
Just tried again and it's working just fine, a mod can close this.
Message 4 of 4
All Replies
one of 2 things could be happening
ether the ethernet adapter in that device is only 100/10M or the ethernet cable is not right
i assume you plan speed is 100/40M
i assume you are in the states and are using the same server in NY for your tests
Message 2 of 4
SSuffolk
Guide
I did find when I restarted my computer I got better speeds, but not exactly what I pay for.
I pay for 110 down and 35 up
It starts off strong then just tanks into the 30-40's
Message 3 of 4
SSuffolk
Guide
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 9956 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
