- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wireless Half the Speed of Console
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wireless Half the Speed of Console
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wirelessly my laptop will exceed those speeds. Other wireless devices I own also get about half that wirelessly (iPad, iPhone, droid phone, etc). My Xbox on the other hand will only get at best 35Mbps down/ 20 up still. Tried several options but couldn't ever improve speed. Bought an Ethernet cable and boom, getting 120 down 22ish up. Any explanation as to why the Xbox speeds would vary that much between wired and wireless when my other devices do better?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Xbox wireless adapter drivers in there consoles have never been top notch or good performing. There are known various problems with some of there wifi adapters. Reason why it's recommended to always use ethernet connections for gaming consoles.
@Alejandrin wrote:Wirelessly my laptop will exceed those speeds. Other wireless devices I own also get about half that wirelessly (iPad, iPhone, droid phone, etc). My Xbox on the other hand will only get at best 35Mbps down/ 20 up still. Tried several options but couldn't ever improve speed. Bought an Ethernet cable and boom, getting 120 down 22ish up. Any explanation as to why the Xbox speeds would vary that much between wired and wireless when my other devices do better?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware is 2.7.2.104
The modem I have is an Actiontec C3000A
The Orbis are about 20 feet away. I have the main in one corner of the house in the basement and the satellite in the middle of the house main level.
With basement its about 2000 sqft.
I have enabled BeamForming MIMO and WMM
I have disabled all except the coexistence I will try that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your modem has a built in router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ugh it took me 3 hours to get it to do that correctly with my old one. I guess Ill be spending the day doing that tomorrow lol. So I have set everything up based off of the thread that was shared and I am still getting about 60 down on my mobile phone. Laptop is better but I am also infront of the main Orbi
