Orbi WiFi 7 RBE973
Reply
Wireless printer periodically connecting/disconnecting from Orbi router - SOLUTION HERE
KiwiChris
I have a Dymo wireless label printer on my RBR50 Orbi AC3000 network.
I use the Dymo label app from my iPad iOS.
Every so often I see the wifi light on the printer go from solid on, to flash then go solid again and at that point the app says "printer not connected". Sometimes I can refind the printer, sometimes I have to reboot the app and/or the printer. Sometimes I can't seem to refind the printer and after a few minutes of trying give up and come back later.
i was trolling this site looking for answers and found a previous thread from last year that suggested all sorts of setting changes on the Orbi router.
One was to disable the Daisy-Chain setting under Advanced/Wireless.
This worked and my printer now stays connected. HTH
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Accepted Solutions
Mstrbig
Master
Re: Wireless printer periodically connecting/disconnecting from Orbi router - SOLUTION HERE
So you found the solution. Can you mark this solution found, so others who have the same issue will see the solution?
Message 2 of 2
All Replies
Mstrbig
Master
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 959 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
