- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Xfinity gigabit plan but Orbi maxes out around low 500Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xfinity gigabit plan but Orbi maxes out around low 500Mbps
Already logged ticket and was given the usual newbie script back, replied to that but had nothing back yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would do this as well. Power OFF the ISP modem, Factory reset the RBR. Leave the RBS off. Power ON the ISP modem. After it syncs, walk thru the setup wizard and set up from scratch. I would not set a new SSID here, just leave it as default for now. Be sure not to enable QoS, Traffic Meter or any Access Controls or Circle or Armor. After the RBR is setup, use a wired PC and Ooklas installable speedtest app. Run some speed tests. Let us know what you find out with this configuration. If your still seeing the same issue, I presume there is a problem at the RBR with WAN to LAN speeds as seen here: https://community.netgear.com/t5/Orbi/Orbi-RBR50-is-not-supporting-900Mb-on-the-WAN-to-LAN-test/m-p/...
@interestedperso wrote:
Thank you all, i am going to have a play with the MTU setting and turn of daisychaining when i get home as from reading threads i note some have had luck with this approach.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well shoot. Went to open a ticket and looks like my phone, chat and email support have expired. But I still have the hardware warranty. How do I submit a ticket if they so all my options expired by I'm still under hardware warranty? I filled out the support form and the only two options I got are this community forum and the knowledge base.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would contact the forum moderator and hopefully they can direct you.
Good Luck.
@PoorOldRudy wrote:Well shoot. Went to open a ticket and looks like my phone, chat and email support have expired. But I still have the hardware warranty. How do I submit a ticket if they so all my options expired by I'm still under hardware warranty? I filled out the support form and the only two options I got are this community forum and the knowledge base.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was, i then turned daisychain topology off, after restart i got 520mb via speedtest.net from the satellite wiresless, bingo. I hope it helps anyone having speed issues when satellite etc is connected via ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The OP is not even getting near 900Mbps with just the RBR via wired PC.
Wireless speed will max out at around 400-500Mbps for current wifi devices. Depending upon Mfr design and support.
I had a play tonight first checking mtu setting was good using https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 Saw several of your posts recommending users to hardwire straight into the Orbi and do a speedtest through the app and not the site. I did get a couple test results in the 600-700Mbps range. But most landed in the 400-500Mbps range. So the speed is there, almost, but something is getting in the way. I know it's cable which can degrade when other people around you are using it. Which could be part of it. I had a tech who came out to test my equipment tell me we are on a shared line with 20 other people. So... there is that.
While on the Orbi's wifi I have tried several speed tests on the http://www.dslreports.com/speedtest which have came back in the 500+Mbps range. Has anyone ever tried the dslreports speed test?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya seems like something in the RBRs FW and or HW is not fully getting or allowing near 900Mbps...
Ya, used dslreports.com before as well. The test I run is more local and has no internet processing interferences.
- « Previous
- 1
- 2
- Next »
