- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
a device always gets connected to the main ORBI router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a device that always gets connected to the main ORBI router, although the satellite is very near to it.
Is there any solution for this? So that I can assign it to get connected to the ORBI satellite first?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: a device always gets connected to the main ORBI router
- Mark as New
- Bookmark
- Subscribe
- Permalink
The orbi itself dynamically moves devices around as needed. Is it causing an issue or is it functioning as it should?
One thing to check is distance. The orbi's require at least 30ft between them for the switching function to run as it should. Are they that far apart?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should I have beamforming on?
Is there a downside to it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
And yes, Some device performance reduces when they are connected to the Main ORBI, with law signal
- Mark as New
- Bookmark
- Subscribe
- Permalink
20 feet is too close. WIfi over lap maybe too much. 30 Feet starting with the RBS from the RBR.
Beamforming is good to have enabled.
@willis3 wrote:
My satellite was only about 19 feet from the router, moving it now
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I’ll try turning on beam forming
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Moving it further will reduce the signal and therefore the performance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats the current distance between the RBR and RBS?
Any building materials in between the RBR and RBS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ORBI Router is in the next room to the room where the satellite is.
There is an open door between both too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
20 ft is to close for them to function properly. If you're that close and have a poor signal between the units, either something in your building materials (hvac, plaster lathe, concrete, brick, adobe do a great job at stopping wifi signals) is blocking the signal or one of your units is bad. I usually lean toward it being a building materials issues just because its one of the most frequently seen issues. I know you put there's an open door between them but unless they're line of sight, the walls can still be blocking the signals.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also lead based paint can cause problems as well.
Older homes 70's era and older may still have lead based paint in the walls, though maybe covered over my other new layers of paint. Still could cause problems for wifi signals.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
