Reply
Highlighted
Follower
adding satelites
Am I able to add an addtional satelite to the RBS50???
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 3
Highlighted
Guru
Re: adding satelites
If you want to daisy chaing satellites, then yet. You'll need to enable Daisy Chain feature on the Orbi router.
My Setup (Cable 900Mbps/50Mbps)>CAX80(Modem Mode)>RBK853 v3.2.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Highlighted
Luminary
You can, I did recently.  The satellelite I added was over a year old and had never been used.  It was so old that the firmware update would not work.  Took a bit of trial and error to determine how many updated I could jump.  After manually install two updates, it finally auto updated to the latest one.  After that it has been as rock solid as the rest of my system.
RBR50, 2 RBS50's AP Mode, wireless backhaul
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 379 views
  • 0 kudos
  • 3 in conversation
Announcements
