- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
allowing ports on orbit router
- Mark as New
- Bookmark
- Subscribe
- Permalink
How can I open ports to allow roomba to connect to wifi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: allowing ports on orbit router
What model Orbi do you have?
Ports shouldn't be opened for the Roomba to connect. Is the Roomba a 2.4Ghz only devices or a dual band device?
Does the Roomba see the wifi SSID name at all?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi RBR40
Only runs on 2.4
internet access is metronet
Called Roomba mutiple times and was told firewall is preventing and that certain ports need to be open. Netgear is out of customer support and they want $168 to open ports
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the Roomba connects however does not get any Roomba services thru the orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can see the roomba on my phone but does not connect to the vacuum. I believe the modem is technicolor model VEN501-NA
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mode is your modem working in? It's a modem with built in router and wifi I believe.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can try this to see if your phone and Roomba app connects to the Roomba
Netgear provides a simple mechanism to accomplish this:
Log into the Orbi web interface (http://orbilogin.net)
Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
Uncheck the box, "Broadcast SSID on 5G"
Click "Apply"
All devices that are currently connected to the Orbi will remain connected.
On the smartphone, go to wireless settings and "forget" the Orbi SSID
Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
Open the app and set up the 2.4G device.
Once the device is connected and working as it should, reverse the steps.
Check the "Broadcast" box and click "Apply"
"Forget" the Orbi WiFi. Search. Enter password. Connect.
Be aware that there seems to be a time limit with some iOS or Android devices that will connect to the 2.4Ghz radio for a short period of time before changing automatically to the 5Ghz SSID, even though it's been hidden. The SSID is hidden only, thus the signal is still present. So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use a Roomba 960 without opening any ports or doing anything different to the Orbi settings. In fact, I use the Guest network for my "internet of things" devices like Roomba and Ring devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you! I have a new Roomba i3, spoke to Roomba they said I could have same connection problems with any Roomba, perhaps a firewall blocking the ports?? Unfortunately it's over my head Orbi is out of customer service and will charge $168 to go in and open ports...... I paid enough for Roomba and don't want to pay to actually use. Internet service suggests static IP but charge for that as well. I use guest 2.4 for many other wifi products in my home and don't understand why Roomba is so different
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try connecting your Roomba to the ISP Modem, wifi and router there. Turn OFF the Orbi system to see if the Roomba will connect there. If so, then you need to configure the modem or router as suggested in the options given.
@trcy923 wrote:Thank you! I have a new Roomba i3, spoke to Roomba they said I could have same connection problems with any Roomba, perhaps a firewall blocking the ports?? Unfortunately it's over my head Orbi is out of customer service and will charge $168 to go in and open ports...... I paid enough for Roomba and don't want to pay to actually use. Internet service suggests static IP but charge for that as well. I use guest 2.4 for many other wifi products in my home and don't understand why Roomba is so different
