Orbi WiFi 7 RBE973
Reply
attached devices shows devices that are physically wired as connected via wireless
Jroach
Luminary
Having issues with network "thrashing".
General: I put in Orbi a few months back.  Continuosly troubleshooting things that I can't quite figure out if I'm having multiple device issues or an Orbi issue.  The satellite has already been replaced.
Problem: One specific issue I see is that I have a server that is wired directly to Orbi.  When looking at attached devices it shows as "2.4Ghz Guest".  Wireless is turned off at the server and I don't even have the "Guest" network enabled.  If I reboot Orbi it will show "wired" for a few seconds then switch to 2.4Ghz Guest.
Once I can figure this out I want to try and determine why some devices show "2.4Ghz guest" vs "2.4Ghz".
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 10
Jroach
Luminary
Re: attached devices shows devices that are physically wired as connected via wireless
Quick edit/addition:
When the server shows up as being connected "2.4Ghz Guest" it is attached to the satellite not the router.
Message 2 of 10
Guru
What FW version is the router system using?
Maybe something that will be changed in next FW update.
Message 3 of 10
Jroach
Luminary
Good question.  I am on 2.1.2.18.
I have heard that this version is a BIG problem but I can't figure out how to go back to the previous version to see if my issue is related to firmware.
Message 4 of 10
Jroach
Luminary
I found the old version of Firmware.
Downloading now and will install/report back.
Message 5 of 10
Guru
Well if this is just a display issue and the system is working otherwise, it's recommended to keep whats loaded.
However, let us know.
Message 6 of 10
Jroach
Luminary
Downgraded the firmware per my previous post.  For anybody reading this make certain you downgrade the satellite first.  I didn't follow that step and it was a real pain to fix it.
So far the devices are showing up correctly.
Message 7 of 10
Guru
Good to hear it's working better.
Enjoy.
Message 8 of 10
Jroach
Luminary
Thanks!
Message 9 of 10
Guru
Hope next update will be good.
Enjoy for now.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1421 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
