Reply
can orbi satelite alone works with different router than orbi router?
HannoosH
I just Bought RBK50, it is on the way .. while I was checking I didnt find clear information about the possibility to have the ORBI satelite works without orbi router .
Other products like Nokia Beacon 3, each unit can work as Satelite and mesh router .
hope that this will be possible .
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 4
Chuck_M
Mentor
Re: can orbi satelite alone works with different router than orbi router?
No... you need an orbi router to work with an orbi satellite.
My Equipment: Cox Cable (350Mb/35Mb), Orbi AX6000 (RBR850, 3 x RBS850) (2xWired backhaul), NG GS116PP Gigabit Smart Switch, Synology DS1019+ NAS
Message 2 of 4
Guru
The one time I tried this, I had my satellited wired to the Orbi base. I removed the base and changed to a different router, leaving the satellite ON and connected via LAN wire to the different router. It continued to. I didn't power OFF and ON the satellite to see if it would operate after that. I presumed it wouldn't as it probably needed to checking with the base that was no longer there. So this portion is not proven.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.223/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 3 of 4
The RBK50 is an Orbi kit that comes with an Orbi router (Model RBR50) and an Orbi satellite (Model RBS50).
If that is what you bought, were you planning to use the satellite somewhere else rather than with the router that is also on its way to you?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1375 views
  • 0 kudos
  • 4 in conversation
Announcements
